Kenmore Oven throwing PF codes
I have a Kenmore oven that works for awhile, then throws a PF code and then turns itself off. I have to bang on the top of it for it to display 8888 and then slowly set the time again and I restart my bake period. If is starting to to it more often. My stove model number is 665.95014102. (bisque)
I am guessing (and it is a guess) I may need a CONTRL BOARD PART # AP3174668. However this board is about 300.00 dollars. Does anybody know what may need replaced on the board? Or what the pieces are on the board below so I can check the connections? I already replaced a wire connector that connected to the keypad tab which seemed be loose. I pushed on everything on the back of that board to see if it would throw the code but the keypad connection was the only thing that did it.
It will be cheaper to pay for service visit from sears $65 or so to find out for sure.
Most likely the problem is a bad control board which probably has some traces micro cracked, but before you replace it I would recommend to check how good the range is grounded.
Power Failure. reset clock.
To “guest” responder from 2 years ago… come on, man… read the post.
