[quote=My_Bucket;278155]My oven door won’t open. I realize it’s the hinge. So I bought the new hinge and when I tried to install it. I noticed the hinge screws on inside the door. It appears I can’t replace the hinge without opening the door. But how can I open the door with a broken hinge?
Help…[/quote]
Open the door VERY CAREFULLY,
Are you sure the hinge is broken ?
Or did the claw catch just come off the reciever pins inside the oven face frame ?
Or a broken reciever ( not likely)?
There are several versions of this style oven door hinge.
Some have catches on the hinge itself, some have 1/8’ holes in the hinge, that you have to insert a nail or screw in to hold the hinge in a locked position, to remove the door assembly.
Basic procedure is :
Open the oven door to the full open position.
Insert pin in hole in hinge , or push clip on pivot point forward and lock into catch
Grasp and lift up on top of door(like if you were going to close the door) until claw on interior releases, from pin on reciever inside cabinet frame/wall.
Once you get the door off, if the hinge claw has come off pin and is not damaged, you can re position the claw, and seat pin or insert pin in hole and re install door assembly.
Insert claw(s) into recievers, press down slightly on top of door assembly, remove pins or release clips on pivot and slowly close the door, repeat several opennings and closings to insure claw has seated properly on reciever pin.
Good Luck,
