Kenmore oven - Controller vs. Board
What’s the difference between the Controller and the circuit board? The exploded diagram shows the board as an inset, but not how it installs in the backguard. I have a broiler that stays on whenever “bake” is selected and I was hoping to order parts before I pulled it all apart.
In case anyone else looks at this, the extra circuit board in the exploded parts diagram is the Simmer-Slect board and is not really part of the backguard. The circuit board attached to the Controller is an integral part of the controller and is apparently not available separately. The overlay is not included with the controller. So if you have popped a small resistor on the circuit board, as I did, you must order the entire Controller.
