Kenmore needs new control board?
My Kenmore washer is doing the beeping/flashing routine I’ve seen in other posts. Trouble is, I can’t even get a valid Error Code from it. If I hold the Start & Pause/Cancel buttons in, the five lights for the first digit flash 6 times and the light for the second digit flashes 3 times. I doubt the veracity of these results because 1) there is no Code 63 in the troubleshooting chart and; 2) valid codes are supposed to repeat after a two-second delay…this never does.
Here’s my question: Is it safe to assume that my control board is fried? I’d hate to spend $120 on an un-returnable item I didn’t need. Thanks for any insight you may have on this!
It is safe if you order it from Appliance Parts Pros because of their very friendly return policy.
