Kenmore Microwave Door Replacement
The door frame to my microwave is cracking and is broken in a few spots around the handle. I purchased the replacement door from Sears. I have tried to take the door assembly apart by removing the three screws, but I have no idea how to get the outer door assembly off… HELP!!!
Thank you.:stuck_out_tongue:
Corinne,
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
Nat
I just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. I certainly am no expert, but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great. Good luck!
Tyler
[quote=Corinne Sayles;49599]The door frame to my microwave is cracking and is broken in a few spots around the handle. I purchased the replacement door from Sears. I have tried to take the door assembly apart by removing the three screws, but I have no idea how to get the outer door assembly off… HELP!!!
Thank you.:p[/quote]
