Brand:Kenmore Kenmore Model Number: 795.51737810 Main Symptom: Ice maker is not receiving water although water is received at the door. Replaced Ice maker assembly (AP5959515) and still have issue. What happens & when: Water does not enter the ice maker. It started 3 days ago. Water does come out of the door so I suspect it is NOT the water filter.
I suspect the valve ( LG AJU34125567 Refrigerator Water Inlet Valve Assembly | Genuine OEM Part ) that feeds water to the Icemaker has failed. One way you can verify this is to listen at the valve when the icemaker calls for water and see if you hear it buzz. Next disconnect the line to the icemaker and see if water comes thru the valve when energized
