Kenmore Ice Maker Not Making Ice
Of course its just over a year and out of warranty, but i have a kenmore model number 253.7419240R and the ice maker just quit making ice. it is not getting water to the ice maker. the water feed solenoid has been replaced, there is plenty water pressure, no blockage or ice buildup on feed tube in freezer. seems to be a problem with sending the signal to the solenoid to feed water to the maker. i checked all three micro switches in the maker and all are functioning, everything in the ice maker works except its not getting water. any help would be appreciated, tired of spending money on parts that arent the problem. thanks.
Does the ice maker harvest?
Did you check the wire harness?
  • The part number for the ice maker is AP3160597
the ice maker harvests, wire harness is good and is getting power, i believe i may have found the problem, goin to let it cycle and see if i get any ice, finally getting water, took the whole ice maker back out and let it sit at room temp for a night, now seems to be working, ??? dont know why but ill give it a try thanks
Keep us posted.
ice maker all working fine now. guess it just needed a good defrosting. after i took it out and let it thaw overnite, works fine now. hopefully it keeps working lol
