Brand: Kenmore Ice Maker
Model Number: 106.89592102
Main Symptom: Producing very little ice and water won’t shut off.
What happens & when: This happens all of the time.
Error Code (if any): None
Parts or tests already tried: Replaced water inlet valve (part # W10881366); water kept running. Replaced ice maker control board (part # W11034363); machine worked properly for 4 months. Then machine started making too much ice so replaced thermistor (part # WPW10511923); machine would over produce ice intermittently and the control board would flash on/off and accelerator intermittently. Thought possibly the electronic control board (part # W11089498) was bad, so replaced it and nothing changed. The water inlet started running on again. We believe the ice maker control board has gone bad and would like to have it replaced via warranty since it has the same symptoms.
