I have to replace the pump on my Kenmore HE2 washer model number 110.4752602. Do you have to get at the screws from underneath to replace the pump? I cant see how to remove it. Thanks
The instructions are attached to the reply.
- The drain pump AP6023956
Duet sport - drain pump.pdf (392.2 KB)
A big thank you to Gene for the downloadable step by step instructions on removing the HE2 drain pump. I am not the handiest guy, but I was able to take out the pump, remove a rubber band that had wrapped itself around the impeller blade, reinstall the pump, and get back to doing laundry.
You are welcome. I’m glad it did help you and your washer is up and running.
