Kenmore gas dryer model 11072982102
Brand: Kenmore Elite Gas dryer
Model Number: 11072982102
Main Symptom: Pushing Start switch initiates drum turning, but stops when releasing push start switch.
What happens & when: Gas Dryer was working great in all aspects, then one day the push start switch would start the drum/motor turning but as soon as releasing the push button, the drum/motor would stop. If holding in the push switch start button, the drum/motor would continue to operate, but no heat ever came on and when releasing the start button, the dryer would stop.
Parts or tests already tried: AI tool (Claude) suggested that the “Dryer Power Relay” component was likely bad. Ordered from Home Depot the new OEM component but after installing, no improvement was realized. Dryer still not staying on and no heat if holding in push start button. Please help. Need to know if fixing is worth effort or just buy new gas dryer is best solution. FYI, I did “chat” with a live rep on this website and was told it is likely a centrifical switch that is part of the motor assembly and likely need to replace the whole motor assembly?
That is going to be the motor 279787. The centrifugal switch isn’t closing.
If it was heating, I might suspect the heater relay or something else, but no heat even when the switch is held and the motor not staying running even with the motor relay having been replaced means the motor is the issue.
