Kenmore Front Load Washer
My Washer Stopped Adgitating And Spinning. I Removed The Back And Noticed Two Wires Fell Out Of The Bottom Of The Plug To The Motor. One Is Red With A Black Stripe The Other Green. There Is A Total Of Six Wires In The Plug. Could Someone Help? I Need To Find A Picture Or If Someone Could Let Me Know Witch Hole Each Wire Belongs In. Thanks
About all I can advise you to do is to remove the front access panel and see if the tech notes in there have a wiring diagram.
