Kenmore error code F23
My washer stopped washing in the middle of a cycle. The panel lights up and the timer counts down. There is no agitation or spinning, only a click when I press start. When I pressed the start and pause button at the same time I get error code F23:confused:
Check the service data sheet inside, I think this failure code is a no drain error.
You can unplug the washer for 5 minutes to clear this error code.
Thank You…That Error cleared… now I am getting E41 Error
