kenmore elite
Why do I keep getting error code “FH” seven minutes into any cycle that I run? There are no clogged screens or kinked hoses.
Check the pressure switch hose and, if there is nothing wrong then replace the pressure switch (#23 on the diagram).
  • The part number for the pressure switch is AP3128700
Thanks Gene, you were right. This is a great service.
