Kenmore elite water tank
Can you splice the water tank line? My leak is near the connection under the front doors. Seems silly to replace all the water tank lines
Thank you
If there is enough slack in the line, you can cut out the part with the leak and add a john guest fitting that connects the lines together. Part number is [WR02X11330]
