Brand:Lenore I tested the hall plug going into the stater not sure which one is pin one so I took readings from both sides from the side with the locking clip brown to yellow. I had 9.65 brown to red. I had 10 brown to blue I had 10 then going the other way blew to red I had 19.54 blue to yellow I had 19.60 and then from blue to brown I had 10 with the multimeter said at 20 K. Then with the multimeter set on 3MI tested the heater sensor and it came up 100. I think I may have a bad board because when I turn on the washer, the actuator plate rocks back-and-forth for about 30 seconds or so it pops up the E6 code.
Model Number:796-31523210
Main Symptom:E6 code
Did a wash of clothes and then a six code came up my book says it was the clutch. I replaced the clutch with the shifter lever and also replace the shift clutch motor still coming up E6.Error Code (if any):
