Brand: Kenmore
Model Number: 41262
Main Symptom: OE code showing. Won’t drain
What happens & when: Checked the drain lines. No blockages. Unplugged for 5 minutes. Changed the drain pump and water level sensing solenoid. Washer worked for 5 cycles then the OE code popped up again.
Error Code (if any): OE
Parts or tests already tried: Water level solenoid and drain pump.
