Kenmore elite slide in gas oven
My Kenmore elite slide in gas oven - the oven light won’t shut off. Could it be the control pad sensor?
Does it beep when you push it?
If it does then more likely the problem is a bad control board.
If it does not then the keypad,which is a part of the control panel has to be replaced.
there is no beep when I try to shut off the light. Is there anyway I can just remove the light bulb?
Yes, you can do it. Just follow the instructions in the Owners manual.
