I have a Kenmore Elite slide in, smooth top oven/stove combination. Everything works fine, including the broiler, but the bake element won’t come on. We replaced the element thinking that would fix it (Actually, this is the only thing I can do myself that I know of) but it still would not heat.
Anyone have any ideas? Thanks!
Take a voltage reading on the wires coming to the element you replaced you should have 120-240…if you don’t then your main board is probably bad or you have a break in the wire harness somewhere.
