[quote=kenmoresucks;511672]Okay so I’ve had Sears here twice to look at it, fortunately they didn’t gouge us the 2nd time.
F-32 error.
I’ve seen fixes where you can reset the pressure sensor to zero. However, I don’t know where to find the technical data sheet to do this. Is this file available online?
Thank you in advance![/quote]
Kenmore,
Being a Sears/Kenmore unit, The Technical Data Sheet will most likely not be on the internet. But you should find it attached to the inside of the front panel(or inside the control panel)if it has been used.
The F32 code, indicates a long drain time. are you sure the washer drains properly ? There could be a twist ,kink, or clog in the air dome hose, as well.
This may help,
[LEFT][FONT=Arial-BoldMT]TEST #6 Water Level and Pressure Transducer[/FONT]
[FONT=Arial-BoldMT]Calibration[/FONT]
[FONT=ArialMT]This test checks the water level sensing components, and calibrates the pressure sensor.[/FONT]
[FONT=ArialMT]1. Unplug washer or disconnect power.[/FONT]
[FONT=ArialMT]2. Access the machine/motor control assembly.[/FONT]
[FONT=ArialMT]3. Check hose connection between the pressure transducer on the machine/motor control and the pressure dome attached to the tub. Check to ensure hose is routed correctly in the lower cabinet and not pinched or crimped by the back panel.[/FONT]
[FONT=ArialMT]4. Plug in washer or reconnect power.[/FONT][/LEFT]
[FONT=ArialMT]5. Drain [FONT=ArialMT]the tub until all water has been removed from tub.[/FONT]
[LEFT][FONT=ArialMT]6. Remove all clothes from the machine.[/FONT]
[FONT=ArialMT]7. Calibrate the pressure transducer:[/FONT]
[FONT=ArialMT]See Activation of Manual Diagnostic Test Mode, and perform steps 1 and 2 until the display shows [/FONT][FONT=Arial-BoldItalicMT]00 [/FONT][FONT=ArialMT]and the Add A Garment indicator LED is flashing. Press and hold the Cycle Signal button until a single beep sounds, and the display shows [/FONT][FONT=Arial-BoldItalicMT]Pt [/FONT][FONT=ArialMT]to indicate zero calibration has completed. Exit Diagnostic: Manual by pressing [/FONT][FONT=ArialMT][/LEFT]
[FONT=ArialMT]STOP or POWER.[/FONT]
[LEFT][FONT=ArialMT][FONT=ArialMT]1. Be sure the washer is in standby mode (plugged in with all indicators off, or with only the Clothes Clean or Done indicator on).[/FONT]
[FONT=ArialMT]2. Select any one button (except POWER, START, and STOP) and follow the steps below, using the same button (remember the button):[/FONT][/LEFT]
[/FONT][/FONT][FONT=ArialNarrow][SIZE=1]
[LEFT][SIZE=1][FONT=ArialNarrow]Press/hold 3 seconds Release for 3 seconds Press/hold 3 seconds Release for 3 seconds Press/hold 3 seconds[/FONT][/SIZE][/LEFT]
[SIZE=1][FONT=ArialNarrow][FONT=ArialMT]If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with
[/FONT][LEFT][FONT=Arial-BoldItalicMT]88 [/FONT][FONT=ArialMT]showing in the Estimated Time Remaining two-digit display. If indicators do not display as described[/FONT][/FONT][/SIZE][FONT=ArialNarrow]
[LEFT][SIZE=1][FONT=ArialMT]above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. [/FONT][/SIZE]
[SIZE=1][FONT=ArialMT]3. The program then checks for saved fault codes: If there are saved fault codes, see Diagnostic: Saved Fault Codes. If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with [/FONT][FONT=Arial-BoldItalicMT]88 [/FONT][FONT=ArialMT]displayed. After 5 seconds, the Automatic test begins.[/FONT][/SIZE][/LEFT]
[LEFT][SIZE=1][FONT=ArialMT]Good Luck,[/FONT][/SIZE][/LEFT]
[/FONT][/SIZE][/FONT][/FONT]
[/LEFT]
