Can anyone help me.
I have a Kenmore Elite Oasis Washer, blue top loader with the glass, Model # 11028087700
It starts up fine then during the wash cycle it just adds water, spins and drains but never agitates and at around 18 minutes it jumps to 3-4 minutes then drains and spins again but the clothes are always dripping wet and an error code comes on #OL
I get this error code #OL (over load) with or without clothes, either way I still have the same problem even if I just use the clean washer button only.
I read all the info hear and throughout the internet.
I did the test that was posted here by (
[SIZE=4][COLOR=#0000ff]tracehae[/COLOR][/SIZE][SIZE=4], dated 01-02-2010, 10:57 AM[/SIZE][SIZE=4]) by grabbing the inside top lip of the basket on both sides and pull up and if the basket raises about 1 inch then it is ok. But if it does not raise then you know there is a problem, I donβt have this problem as my basket rises up fine. [/SIZE]
[SIZE=4]I read that I might need to have the circuit/control board replaced but thought I would see hear first if anyone has a thought of what I should do.[/SIZE]
[SIZE=4]Thanks for any help anyone can give me.[/SIZE]
γ:confused:
γ
