Kenmore Elite Oasis Top Replacement
There is a lot of rust all around the bleach addition cup. I bought a new top from Sears. How do I get the old top off?
Push a putty knife into the groove between top and front about 6 1/2 inches from each side to release the clips. Now you can raise the top to get to the lid lock and hoses. You will need to remove the control panel and undo the two hinges at the back to get the top removed.
Eric
That did it. Now the rest should be easy. Many Thanks
