Kenmore Elite HE5T washer F-35 SUD code!
Hello, I own Kenmore HE5T Front Load washer model number: 110.2647798K
and serial number: HLW3211421
I have been experiencing SUDS and F-35 code. My washer is 3 years old and I am only using HE detergents. I already blew on the pressure hose and its not blocked or anything. I also called Sears and they cannot locate my washer on their system (how insane is that). It is the right model number (i already checked 3 times, the # is located behind the washer door). Is there any other place to locate the model number?
I have been researching about this problem in this forum, and I found that I may need to replace the pressure switch. I seen that this part, Part Number: AP5264563 looks the same as my pressure switch on my washer.
Any help will be appreciated. Thanks.
I have a Kenmore Elite HE 5T Front Load Washer. I have SUDS & F35 Error code showing up. Sears does not have my Model #1102647788k in the system.
How do I open the Drain Pump Filter to check for debris, like coins etc.?
I turn it Clockwise and Counterclockwise and it will not budge.
What would be the part number for the Analog Pressure Sensor that may be the problem?
Thanks for your help in advance.:slight_smile:
[LEFT][COLOR=#000000] I own Kenmore HE5T Front Load washer model number: 110.2647798K
Read more: http://forum.appliancepartspros.com/newreply.php?do=newreply&noquote=1&p=655422#ixzz2DSGAejJk
[/COLOR]
[COLOR=#000000]Hello, I own Kenmore HE5T Front Load washer model number: 110.2647798K
Read more: http://forum.appliancepartspros.com/newreply.php?do=newreply&noquote=1&p=655422#ixzz2DSFlSY9B
[/COLOR][/LEFT]
