Kenmore elite he3 dryer wont start. Tried several things, Need next steps
Brand: Kenmore
Model Number: elite he3 110.82822101
Main Symptom: Has power, won’t start
What happens & when: select a cycle everthing lights up, push start, nothing happens
Parts or tests already tried: replaced thermal fuses and thermistor. Tested door switch .heating element looks ok and is relatively new. What should I check next?
Based on the information provided, you will need to check the power in and out of the control.
https://www.appliancepartspros.com/repair-help/dryer-repair-help
In and Out of the control board?
