Two summers ago: F1 showed up on display. I messed with it a while w/ no luck. I could re-set it and restart but it would beep again, shut down and return to F1. As a last resort I re-set it, gave it a good hand slap right in the center of the panel and it worked fine. A week later this all happened again. Another good slap and it was fine until last summer when it acted up again. I used the same solution. It responded the same and made it all the way through until this summer. Same deal now. It seems that when the oven is not used for a good while during the summer [when it is humid???] it goes to F1.
I fear that eventually I will knock something loose if I keep slapping the snot out of the damn thing. I’m okay w/ taking it out, checking it over, putting it back, but what am I looking for?
Any advice would be greatly appreciated!! Lakeleader
PS: When I built my house I bought a bunch of appliances from SEARS. One year after warranty they started to go. In the last three years I have had to replace the SEARS Microwave, replace TWICE the control board on the SEARS dishwasher, had to recharge the SEARS refrigerator when it ran low on coolant. Also, the SEARS range hood won’t run right and the SEARS washer has an annoying vibration that is noisy but SEARS says it is nothing to worry about. My wife insisted on only the top SEARS appliances. Seems like the only thing I have from SEARS that works is the refrigerator magnet with the number of their repair line. Take it from me, I will never buy anything from SEARS again. :mad:
