We have a nice dishwasher however it is blinking…pots and pans and normal wash…we just replaced the control motherboard because it it was blinking on the normal wash button and would not go into wash. Could you please tell me if there is a computer reset for this machine that we have to go through after putting in a new board? Thanks so much:eek:
Replacement parts for KENMORE 66513752K602 by Kenmore Elite | AppliancePartsPros.com
There is no specific reset that I know of.
Try unplugging/removing power from the unit for 5 minutes or so.
Blinking lights is often bad keys. It is often a crap shoot as to whether the control board or the control panel (keypad) is the cause. It sounds like you took a chance and lost and the control panel is the problem.
AP6013438
Click on the picture for more info.
See the attachment about the above.
You could also try the following
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Note: There is always a possibility that you received a bad board.
