My Dishwasher door will no longer stay shut. I presume that the latch needs to be replaced. Do I need to remove all of the Torx screws from the inside of the door to get at the latch? The picture shows the 2 screws closest to the latch. Are there instructions available anywhere? Thank you for your assistance.
Yes, you will need to remove all the screws around the inner door panel to access the latch assembly. Here is the part number for you.AP3179951
