Kenmore Elite control panel
I’ve been offered a pretty new (might even be less than a year old) Kenmore elite dishwasher, model 665.16462300. I haven’t had an opportunity to test it, but I’m told the main start button doesn’t work. Apparently other buttons do. It’s a touch screen panel, so I’m using the word “button” loosely. The owners believe this would be too expensive to fix and have chosen to replace the unit. I don’t know if a professional has looked at it or not. Any suggestions on how to evaluate/repair this?
Thanks!
Alison
Replacement parts for Kenmore 66516462300 | AppliancePartsPros.com
Check out it’s troubleshooting section.
Most likely culprits are the keypad (AP3606065) (available in different colors) or the control board (AP3775506)
Check the pin out matrix for the keypad, see the tech sheet.
As you can see keys share wires/tracks so you are trying to narrow down the problem using this.
For instance the Start button uses P1-12 but so do Delay Hours, Rinse Only, Quick Wash and Cancel. So it these keys also do not work then P1-12 is a likely cause.
The usual way to troubleshoot is to check the keaypad outputs with a meter. If it is OK then replace the control board. Still a bit of a crap shoot but your odds are better.
I would try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
16462300.pdf (970.8 KB)
