I have a kenmore elete M # 790.99123405 and S #vf52518501 that has had the clock timer replaced 1 month ago and then the fault code started again with beeping the codes are F 30 And F10 tried to replace the clock timer again and it is still beeping with code F30 . I have no oven at all with this code cane u help? Please!
Deborah
Honest Jims Appl.
Fault code F30 on your model is suppose to indicate a problem with the oven temperature sensor (see the following links).
LINK > Kenmore 790.99123405 Oven Temp. Sensor
LINK > How do I check an oven temperature sensor?
JFYI
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
