Kenmore Electric Oven Control Panel
Brand:Kenmore
Model Number:79094179310
Main Symptom: Electric Oven Control Panel
What happens & when: Oven cycles through oven on repeatedly. Ordered a replacement. Is there a procedure to be done after installing or just install and operate. Manufacturer notes say do oven calibration then temperature adjustment. What’s the process after installing this part.
Error Code (if any):F11
Parts or tests already tried: Ordered new part AP5736343(WI316630004)
All you should have to do is install the control. It does not normally need to be calibrated. Your use and care guide can show you how to calibrate the oven temperature if needed.
