Kenmore DW blinking Clean light
After unloading the night’s before and reloading last nights dishes we attemped to start the DW. No Joy, The clean light was flashing but we couldnt make it do anything else. I read on this forum that you can reboot pushing heated dry normal wash then heated dry, normal wash. That cleared the flashin light and allowed me to start the DW BUT it only fills with water then hums a little then goes quiet. If I push cancel it will pump out the water.
Any thoughts?
UPDATE, Just for the heck of it I tried to run it through a smart wash cycle. It filled .. then I can hear the morot (pump) running but no water is splashin around inside. could this be a cloged selonoid?
Mine is doing the a same thing! No one is responding this problem in other posts ether.
[COLOR=“Blue”]spicermech[/COLOR]
You might have more luck starting your own post using “Post New Topic” in this forum section.
Also a complete model number would help.
Sears numbers are 3 numbers, a period and then 6 to 8 additional numbers.
Note: That Sears does not manufacture anything so even with a complete model number sometimes we cannot cross reference the unit back to the manufacturer to get tech info.
