Kenmore dryer won't stop running unless door is opened
Brand: Kenmore
Model Number: 796.91473210
Main Symptom: Won’t stop running unless door is opened
What happens & when: Dryer keeps running unless the door is opened.
Sounds like the motor relay on the control board is stuck closed.
https://www.appliancepartspros.com/lg-pcb-assembly-main-ebr62707654-ap5680241.html
You would be able to use this service manual:KENMORE 795.851**.900 SERVICE MANUAL Pdf Download | ManualsLib
