Kenmore dryer will not turn on
I have a Kenmore Dryer Series 500. It was working fine. It will now not turn on. It was operating properly one day and the next will not start.
Thanks,
Dave
Replacement parts for KENMORE 11067522600 | AppliancePartsPros.com
See the attachment for the wiring diagram.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Be careful as 240 volts is lethal !!!
If the power is OK the next Item at the top of the list is the thermal fuse mounted on the blower assembly.
AP6008325
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
64642400.pdf (213.9 KB)
