Kenmore dryer running but not heating (again)
Six weeks ago, a repairman put a new thermal fuse in our dryer. It had been running but not heating. It has worked better than ever since then–until yesterday. It is, again, running without heating or drying anything. Is it worth replacing fuses again ourselves, or do we have a larger issue?
Replacement parts for KENMORE 11066942500 by Kenmore Elite | AppliancePartsPros.com
Here is the wiring diagram, see attachment.
Yes you probably have other issues.
I do not know if the service person did any of the following checks but they should have.
Check the heating coil, it may be grounded.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
Was the hi-limit thermostat also replaced?
If yes then I would lean towards the grounded element.
The hi-limit should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut)
66942500.pdf (276.9 KB)
