I have gass dryer that has stopped heating. I have check the Thermal Fuse, the Thermistor, the Thermostat, the Sensor Radiant, the Gas Valve Solenoids and the Igniter with an ohm meter and they all read good. I have then tested the the heat switch and that too is okay. I don’t know how to test the computer board or what else I should check. Help!
Thanks,
Rebecca
