Kenmore dryer keeps running in an automatic cycle
This dryer will just keep running in an automatic cycle after running 2 or more loads. If moved to the timed cycle it will advance normally.
I suspec problem may be the moisture sensor but am not sure how to test. Any suggestions?
Parts for Kenmore Dryer 11067072600 - AppliancePartsPros.com
It has info on the moisture sensor.
I would try cleaning between the moisture sensor strips with isopropyl alcohol.
Just be sure to let all the vapors dissipate before trying the unit.
67072600.pdf (412.8 KB)
