Kenmore Drain Pump
I’m sorry if this question has been already asked. I need to replace drain pump for Kenmore washer 110 4535000. I spoke with Kenmore guys and they said this model is very old and there were no parts available. On the other hand I found this pump from Whirlpool, that said to be the one that should be used instead of original pump. My question is anyone on this forum can tell me which pump I should use for this particular washer I have. Direct internet search for Kenmore parts for this model also does not bring any results.
TIA,
Michael.
Well for starters Kenmore doesn’t make anything… Your washer was made by Whirlpool.
Does your pump have 2 different size ports or are they the same size?
Can you post a picture of the pump?
Nat
