What kind of the tub you have?
To speed up all this Q & A I need you to answer all posted questions.
Sorry about that. It’s a Stanless steel tub. Neal
I would recommend to order the new redesigned heater kit which includes a new control board. It should solve all your problems.
Good luck.
Part has been ordered. Thanks to everyone who helped out. Appeciate you time. Thanks, Happy New Year everyone.
Replaced The heater & control with the new parts that were ordered. Still have the problem. Any ideas?
What is your hot water temperature?
Out of the sink 130 degs. I have oil fired hot water, and the high limit is set at 190 at the furnace.
Any other Thoughts
Test your tub temperature after each fill.
Does the diagnotics check fill the tub or do I have to run it threw a regular cycle?
Just use the regular cycle, diagnostics probably no help.
Feel real stipud! Must of not had the one lead on correctly. Was not on.
Header gets hot now. But the motor doesn’t run, is there a fuse that might of blown when I switched the control?
Does it anything or it’s completely dead?
The clock or face index’s, you can hear the pump run to fill the tub and heat up. Then it would seem to “wash” then empty. The arm on the bottom doesn’t rotate. It’s in the same place every time you open the door.
Double check all wires and plugs under the dishwasher.
Ok, This is the latest. Double checked all connections. Everything looks good. Went to run quick rinse, The clock indexed on the face for awhile, It had filled with water. But the motor didn’t run. The clock showed 2, then emptied. I don’t get it. This has me frustrated.
I can not believe it but sounds like the control board or the wash motor bad.
Check if the power is coming to the motor when the control calls for the wash.
Where at? On the capactor?
The best I can tell is this, I have 120volts on the one leg at the control board for the motor and not the other. I didn’t check down at the capacitor. So would mean the motor is shot?
Did you unplug the motor connector before testing the power?
Did you measure the power between the hot and the neutral at the motor plug?
