Kenmore dishwsher model 665.1677991 leaks only when detergent is used
Kenmore
665.1677991
More than likely the leak is being caused by suds in the dishwasher. This can be caused by excess detergent being used, detergent residue build-up, or improper detergent being used. The easiest steps that can be taken would be running an empty cycle with Affresh to clean any residue, then verify the detergent being used and the quantity necessary for a wash cycle. With appliances changing to be more efficient, less soap is needing to be utilized to achieve the same results. Whirlpool W10282479 Affresh Dishwasher Cleaner (AP4482632) - AppliancePartsPros.com
