Replaced the control card in this dishwasher, re-energized appliance.
Display came up with #2, sounded as if pump or heater came on. Display changed to 1 after 60 seconds, then changed to _ _ on the display and the Normal wash button began blinking. Opened door and closed door, display resumes at “1” for approx. 5 seconds then goes to _ _ again. Open and close door, press cancel to clear counter, Normal wash button begins blinking. Help.
[quote=imanurse;11101]Replaced the control card in this dishwasher, re-energized appliance.
[/quote]
What part did you replace?
What was the original problem?
I replaced the electronic control card Part #8564542 from easy appliance parts. The original problem was the quick rinse light was blinking continuously. No other buttons would work.
