Kenmore dishwasher not heating
My dishwasher stopped cleaning dishes. I tested the heating element and it had infinate resistance so I replaced it. The dishwasher still is not heating.
Remove power from the unit and check P4-4 to P4-3 at the control board.
It should be about 20 ohms.
If it is not then you either have a bad wire or an open hi-limit thermostat.
If OK then when the heating element blew it probably took out the control board.
