Hi, I was hoping that someone might be able to direct me as to how to diagnosis a problem that I am having with a dishwasher in an apartment. It’s a Kenmore Dishwasher, model number: 363.14398991
The dishwasher does not seem to be filling up with water.
I’ve performed the following checks.
- Checked float, looks ok
- Checked float switch, continuity is good.
- Unplugged connector from water inlet value. Started dishwasher and was looking for 120 volts in the connector. All I saw was .7 Volts.
I even ran the same test with the float switch removed and I connected the wires together to remove the switch from the equation.
Is the next step to check and/or replace the timer?
Thank you,
brett
