Kenmore dishwasher not cleaning
Hello this dishwasher is not cleaning the water is hot the level is ok the top arm is not moving when I open the door I ran with door open no water pressure to top arm and very little to bottom arm I think wash pump has little pressure I took bottom arm off it was clean under there all holes are clean.
Remove the pump cover and check the impeller.
