Kenmore dishwasher leakage
Hi
I need your help.
I have leakage in my dishwasher. Water is coming out just above hot water inlet, means the flexible water pipe is connected to for clean water to go in. The water is dripping from 2-3 inches above this connection. Its very slow drop by drop and it leak even if washer is off because the leakage is from the inlet portion of the dishwasher.
I want to know what’s going wrong. What parts (with part number) I need to order?
AMIT DAVE
4163001485
I am not sure that I totally understand.
If the leak is before the water inlet valve of the dishwasher then you do not need any dishwasher parts.
By the sound of it you have to replace/repair the water feed line and you should be able to get this at any hardware/plumbing store (Home Depot etc.).
I would check that the connection where this hose attaches to the house plumbing is tight, could be it is leaking at the fitting but dripping off the hose lower down.
Be sure to use two wrenches one to hold the house plumbing fitting steady and one to tighten the feed hose.
