Kenmore dishwasher model 15839000. Just finished load. Did not use HiTempScrub, but light is on and can’t get to go off. Control panel will not respond.
Disconnect power from the unit for half an hour or so to see if it will reset.
Doubt this will do anything but worth a shot.
Here is the tech sheet
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208533345.pdf
