Brand: kenmore Model Number:AppliancePartsPros Forum Main Symptom: wont spin What happens & when:tub fills with water at stat of spin, agitator works, hear clunk as transmission goes into neutral but no spin. just replace
Could you please provide the model number of your appliance? That will help me look up the correct information and provide the most accurate troubleshooting and parts recommendations.
i have washing machine cabinet removed. The clutch spins , the timer is working to shift the transmission into neutral in spin cycle and the transmission klunks indicating neutral but the drive shaft does not spin
Did you check or replace the motor coupler? A worn or cracked motor coupler is a very common cause of a Whirlpool direct-drive washer that won’t spin or agitate. When it fails, the motor can still run, but it won’t transfer power to the transmission.
