I poured a bucket of dirty water down the drain and turned on the didposal. Sounded like gravel. Sure enough there was pea gravel and who knows what else in the bucket. The thing is jammed. I put a wrench on the bottom and turned it. sometimes it is difficult to turn other times it is easy. when I hit the switch, it is still jammed.
I am unemployed and my dishwasher, dryer, disposal all broke this week. And my furnace needs to be replaced before winter.
I am going down the drain!!!
Can I take this disposal apart and take the gravel and whatever out of it.
AAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHH!
[quote=Nino Hero;273657]I poured a bucket of dirty water down the drain and turned on the didposal. Sounded like gravel. Sure enough there was pea gravel and who knows what else in the bucket. The thing is jammed. I put a wrench on the bottom and turned it. sometimes it is difficult to turn other times it is easy. when I hit the switch, it is still jammed.
AAAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHH![/quote]
It seems to be working again!
