Kenmore Defrost Drain Issue
I have a kenmore refrigerator that has a clogged drain. This model drips down into a pan in the fresh food compartment and then drains into a tube in the back of the fridge. The clog is somewhere in the back of the unit before it comes out the bottom. Initially I tried hot water with some luck in freeing up the clogg but now it’s completely stopped and i’m not even able to get drips of water through the line… Any ideas would be appreciated!
I found a different model #inside the unit, it is 25371792102… In addition to what we did yesterday we tried to snake a line down the drain with no luck.. Hope someone has an idea!
. Once you get the ice out at the top air pressure with a turkey baster etc. will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing
