Hello all,
First and foremost, I have tried searching and found this problem all over the place for side by sides. Thermostat and dampers usually seem to be the culprit. However, for my situation, I can not find a diagnostic manual or any information as to how to approach the situation. The digital temp panel is set at the highest settings right now for both freezer (5F) and refrigerator (41F). Actual temperature in freezer is -12F, refrigerator is ~0F.
This has happened intermittently over the past couple years, but usually freezes once and then has no issues for a few months. This time, the freeze is on and hasn’t stopped. Unit was manufactured in Jan 04.
My icemaker is also bad (IR emitter board is toast) and I was able to find a diagnostic procedure for that. Can’t find one for this issue though.
UPDATE: Thermometer I used originally was busted - refrigerator actual temp is 0deg F and freezer is ~-12deg F. HELP!!!
