Kenmore Coldspot 10657287790 Water Filter
Hello Folks,
I am a newbie to refrigerator issues/components.
Got this one from previous home owner:
Kenmore Coldspot Model# 10657287790
Question:
Does this have an inbuilt water filter? (I couldn’t find it after opening the back)
If yes, any manual/docs on how to replace it?
No, this model does not have a build in water filter. You can install an outside in line water filter on the back of the refrigerator.
Thank you so much for fast response. I tried searching for a good in line water filter but could not find one (comparable to Pur or Brita). Most only remove chlorine and odor. Can you please recommend one? (if permitted by forum rules). Thanks.
Most of such water filters are about the same. The following water filter made by GE is a little bit better than average.
