Brand:Kenmore
Model Number:59666952401
Main Symptom:Not cooling
What happens & when: Oct.17 '26
Brand:Kenmore
Hi all,
Oct.17 '26 just out of the blue, my Kenmore bottom mount freezer and fridge stopped cooling. Ice tray melted, other food softened.
This is what I tried :
No luck. The fan keeps continously running. There are a few clicking sounds which I don’t understand. The water tray at bottom is dry. I’ve touched the compressor and it is warm and vibrating. I’ve given enough time 12 - 16 hours after each adjustment. A bottom mount freezer cools the bottom freezer and diverts some cool air to the top fridge. But the freezer is not cooling.
The appliance is 20 years old
Any tips, advice would be much appreciated
You’ve already done quite a bit of troubleshooting on your Kenmore 596.66952401, and I wouldn’t replace any more parts just yet.
The biggest clue is that the freezer isn’t cooling, even though the compressor feels warm and vibrates. Since the refrigerator gets its cold air from the freezer, we need to find out why the freezer isn’t producing cold air.
Here’s what I’d check next.
This is the most important test right now.
Here’s what the different patterns mean:
Light frost across most of the coils
The sealed cooling system is likely working. We’d then investigate airflow and temperature controls.
Coils completely packed with frost or ice
This points toward a defrost problem, such as the defrost heater, thermostat, or control board.
Frost on only the first section, or no frost at all
If the compressor is definitely running, this suggests a sealed-system problem, such as low refrigerant, a restriction, or a weak compressor.
You mentioned hearing clicking sounds. Those could be important.
With the refrigerator running, check whether the condenser fan beside the compressor is spinning. Also observe whether the compressor runs continuously or clicks off every few minutes.
A warm, vibrating compressor doesn’t necessarily mean it’s pumping refrigerant properly. However, if it keeps clicking off and restarting, we need to investigate the start circuit, compressor overload, and compressor itself.
I’d return the refrigerator and freezer settings to approximately 4 and restore the performance adjustments to their original values of 5.
Increasing these settings won’t correct a mechanical cooling failure and could complicate troubleshooting.
Because both compartments stopped cooling, you’ve already replaced the start device, and the compressor appears to be running, I’m concerned about a possible sealed-system or compressor failure.
But I wouldn’t condemn the compressor without seeing the evaporator frost pattern first.
At 20 years old, an expensive sealed-system repair may not be economical.
Those two answers will help us narrow this down without spending more money on unnecessary parts.
In the meantime, don’t rely on either compartment to preserve perishable food until you’ve confirmed safe temperatures.
Do you like this personality?
Thanks for the detailed explanation Jeffrey, contains so much valuable info.
I’ve let the unit run for over 16 hours thru the night. The fan runs constantly not stopping at all, just humming.There are a few intermittent sounds, but not like the click trying to start the unit. In the morning, the freezer is warm, not the slightest bit of cooling.
At his point, I’ve given up and starting to look for a new unit as we cannot wait any longer. After 20 years of service, time to let go.
Thanks all,
Cheers !
